PC Specs: This is for €550
-Core i5-4690 3.50 GHz S1150 6mb (Intel)
-8gb 1866MHz DDR3 Non-Ecc Cl9 Dimm (Kit of 2) Xnp Predator. (Kingston)
-500gb Deskstar Sala 6gbs 32mb 7200Rpm 3.5 (Hard Drive)(Toshiba)
-Neos White/Red.(BitFenix)(Case)
-H81M-E34 Mitherboard lga 1150 Intel H81 DDR3 VGA USB.(MSI)
-Pulse 750W 120mm Silent Red Fan Sala PFC PSU. (BestValue)
-Geforce GTX 950 Gaming 2gb GDDR5 Twin Frozr V Fan Pcle 3.0. (Msi)
-RG-100 Led Gaming Keyboard.(Keyboard)
-300mbs Mini Wireless N Usb Adapter.(Router)
I was planning to build my own rig and this was going to be the specs:
this is for €640
-AMD FX-6300 3.5GHz(4.1 turbo) 6 core
-8gb 1866Mhz DDR3 Kingston ram
-1TB barracuda storage
-Game Max GM-One Knight Midi Red – USB 3.0
-Gigabyte GA-970A-DS3P AMD 970
-500w Aerocool integrator
-Geforce GTX 1050 2gb
how will this preform? This is also a pre owned rig so i cannot change anything on it unless im upgrading in future thanks to those for getting back!
Edited by Krause
https://linustechtips.com/topic/692595-new-rig-need-help/
I dont understand? Do you already own this and upgrading or buying a pre-built? Can't find anything much about the PSU, but it seems really dodgy from the name. 950 is a really bad value card, look for a 460 or 1050/ti instead.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8881910
no i said that its pre owned meaning someone is selling it second hand
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8881911
For how much? What is your budget?
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8881914
never go with a shady PSU....
You can literally DIE
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8881915
Just found some info on the PSU, unsurpassably its absolute crap and a fir hazard. If you decide to purchase this, factor in the cost of a new PSU, that one is not safe.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8881928
43 minutes ago, Krause said:
so you pick the AMD build?
I would go for the second build, but change the CPU to and i3, faster and much easier to upgrade. It also wouldn't be a bad idea to get a PSU that is a little better, that one still isnt that great.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/692595-new-rig-need-help/#findComment-8882014
