Will it work
Go to solution Solved by NannerBeans,
I think everyone here is missing the point of this thread. He already owns the gpu and that amount of money won't get you anything better so there is really no point in debating that. That build looks fine. Go for it. I'm sure if he was able to get an i3 6100 he would but that's much more expensive.
It should, although I'm pretty sure the X4 isn't on the FX cpu's only athlons, but yeah, I'd probably go for an athlon 860k though. There isn't much of an upgrade path but going with AMD will give you little upgrade path anyway.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871384
If this is a new build though you would be better off getting an amd apu like the a10 7860k rather then that though.
Better gpu performance.
http://gpu.userbenchmark.com/Compare/AMD-Radeon-R7-Graphics-vs-Nvidia-GeForce-GT-730/m8791vsm12582
Similar cpu performance.
http://cpu.userbenchmark.com/Compare/AMD-A10-7860K-APU-vs-AMD-FX-4350/m83781vs2880
Plus it will be cheaper, and use less power.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871405
1 minute ago, Alaa said:
http://pcpartpicker.com/ Use this website
2 minutes ago, Alaa said:
pcpartpicker.com
Could you not double post?
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871406
the 860k has a  FM2+ socket
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871408
Cheaper socket.
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871411
In Bulgaria the FX4300 is cheaper
Ooh, cool, a friend is offering an FX4130 and am3+ mobo for 15$
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871452
5 minutes ago, Thread212 said:
Why dont u just take a look at this built?
$500
http://pcpartpicker.com/list/hMT6BP
what are u going to use that pc?
because GT 730 are junk
and amd x4 is an old cpu.
also how much is ur budget?
1st i have storage
2nd i need a quad core
3rd budget is around 200 euro and the reason that i put a GT730 is that i have one in my dell
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871493
42 minutes ago, subjectx5 said:
Motherboard: ASRock 980DE3/U3S3
CPU: AMD X4 FX-4300
CPU Cooler: be quiet! PURE ROCK
RAM: 2x4GB DDR3 1600MHz Corsair
GPU:Gigabyte GT730 2gb gddr5
PowerSupply:be quiet system power b8 550w
Case:RAIDMAX VORTEX Black
What is your actual Budget?
IM BACK BABY
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871564
4 minutes ago, Thread212 said:
1-okay
2.I3-6100 is a dual core but will perform better than the FX 4300 and consume less power. also lga1151 is more futureproof. but if u dont have the money then its allright
3.If u have one then its no problem just dont buy one.
What about an apu instead of a gpu?
IM BACK BABY
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871588
1 hour ago, kurtstir said:
Oh you already own it ok
But the point is, he shouldn't own it... :P
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8871979
14 minutes ago, subjectx5 said:
dw next year gettin a gtx750
Don't, there are so many better cards for the same price.
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8872088
https://linustechtips.com/topic/691700-will-it-work/#findComment-8872152
3 hours ago, subjectx5 said:
like?
Look on eBay.. There is a 760TI for 79$ second hand here.
Specs v-v
https://linustechtips.com/topic/691700-will-it-work/#findComment-8873145
