TECH EXPERT I NEED HELP DECIDING
Go to solution Solved by cube45,
It depends. The 1070 is better price to performance wise but it will still be overkill if you are just gaming on a single 1080p monitor at 60 fps. If you plan on gaming at higher resolutions / frame rates / VR then the 1070 is well worth it.
I NEED HELP!!!!!
i originally wants to buy gtx 1070. but my friend came across me and told me that he wants to buy gtx 1060.
this makes me asking which should i buy, gtx 1070 or gtx 1060?
what is the reason that made me should buy gtx 1070?
what is the reason that made me should buy gtx 1060?
for all tech expert out there please, i need answers.
thank you all
https://linustechtips.com/topic/691598-tech-expert-i-need-help-deciding/
1070 has better performance, but is also a bit more expensive. If you can afford it, buy it.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
depends what your monitor needs , if its a 1080 p monitor the gtx 1060 will do just fine with most new titles but if your monitor is higher like 1440 and you dont want to spen money on the gtx 1080 then get the 1070 preforming better but i would suggest 1070 if you can afford. if 1070 get the evga 1070 ftw
well, i guess i know the answer then. GTX 1070 (i think im gonna go with the FTW one just for that glowing thing)
thanks for all of your answer guys
19 minutes ago, rwaalph said:
Gtx 1070 is better than 1060 in overall he may not have a budget for higher end card thats why your friend like 1060
14 minutes ago, AlwaysFSX said:
Here's some performance differences. Do you feel the need for more performance? Do you intend to replace the card sooner or later?
  Reveal hidden contents
11 minutes ago, Tech_Dreamer said:
1070 is a mid range tier, should perform like one, if you have the m0oney, then go with it,
Make sure to mark the thread as solved using the tick on whichever post was the bestest.
