Hi guys!xD I need advice for my first PC build which I will be using mainly for gaming (OSU!, CSGO, BF1) and game development in Unreal engine 4 and Unity Engine, as well as some light 3D modelling. I plan to keep the total cost under SGD $3000 as much as possible.( Yes i live Singapore :) )
I have some parts from my brothers old build that he has kindly donated. A corsair CX750M, some AF140's, an MSI R9 280x Gaming 3GB, and a random Windows 10 key. I plan to reuse the PSU but for the graphics card I'm not so sure as to reuse it and wait till next year for AMD to release their new Vega GPU's or to get a 1060/1070 now. And I also need a monitor recommendation, one is enough for now.^_^
I have two builds I'm choosing between in mind but I'm still open to suggestions. (Side note I would really prefer air cooling my CPU)
Price sheets for each build: Build 1.http://www.cybermind.com.sg/pdf-upload/pricelists/cybermind.pdf
                                                Build 2.http://www.fuwell.com.sg/uploads/misc/Fuwell121116.pdf
                                                Feel free to mix and match from either one. I didn't for convenience sake. :P
Build 1.
5820k + ASUS X99 STRIX MOBO COMBO -$1096
Corsair Vengance LPX 4x8GB -$299
Phanteks Enthoo Pro -$169
Cryorig R1 Ultimate -$139
Samsung 750 EVO 240GB -$119
WD Blue 3TB -$147
Zotac GTX 1060 amp! edition -$399
Corsair CX750M -$0
Total: SGD $2368
Build 2.
6700k + ASUS Z170 Pro Gaming Aura -$812
Corsair Vengance LPX 2x16GB -$289
Corsair 400C -$159
Cryorig H5 Universal -$85
WD Blue 3TB -$143
Gigabyte GTX 1070 G1 Gaming -$729
Corsair CX750M -$0
Total: SGD $2336
Any suggestions and help are welcome!:)
Thanks!
Edited by Rengark
https://linustechtips.com/topic/691596-first-pc-build-need-help/
First, I love the formatting. Looks great!
Second, no optical drive? How will you watch a DVD? :(
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870402
Have an external usb optical drive sitting around some where :P
6 minutes ago, deXxterlab97 said:
I assune you have 1070 on no2. Go no2
oh yeah oops missed that out :o thanks!
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870416
First off, why are you spending so much on the motherboards and you can just build one system for both of your needs.
My Current Rig:
CPU: Intel Core i5-6600K CPU Cooler: Cooler Master Hyper 212 EVO GPU: ASUS STRIX OC 1070 Motherboard: MSI Z170-A Gaming M5 Memory: Corsair Vengeance LPX 2 x 8GB DDR4-2400 Storage: A-Data Premier 240GB SSD/Seagate Barracuda 2TB 7200RPM Case: NZXT S340 PSU: Corsair RM750i Monitors: Acer R240HY/ Dell S2716DG
https://pcpartpicker.com/list/xwcjLD
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870444
Oops, my bad. Just realized it's not in usd.
My Current Rig:
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870445
Well I didn't make it clear my bad, but I am building one system. I'm asking which is a better option.
Well 1SGD = 0.7~USD so not that far off but it adds up.
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870457
What about a keyboard and mouse?
My Current Rig:
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870464
Here's a great build for what you're looking for. http://pcpartpicker.com/list/GCQpr7
My Current Rig:
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870471
35 minutes ago, The Belgian Waffle said:
Based on what I know, when it comes to 3D modeling, the more cores you have, the better. Even the i7 4 cores 8 threads of my Gf's PC isn't enough to handle what she does, the rendering times are awfully slow.
Will the 5820k's additonal 2 cores and 4 threads make a big impact on the render times?
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870497
That is a configuration I would definitely put into consideration. GPU prices in SG are very high though, a 1080 is easily 200-300 USD more expensive than the normal prices in other countries......
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8870529
Really? Wtf lol. Maybe stick with a 1070 if you can than.
My Current Rig:
https://linustechtips.com/topic/691596-first-pc-build-need-help/#findComment-8872674
