I have an intel motherboard with a red led light. I have never had a motherboard with a red light. i tried to boot it up without a heatsink (there were a few messages) and it crashed. The red led light stayed on and would't boot, and so i bought a new heat sink and installed the heat sink. I removed the battery and reset the CMOS and it is as if I hadn't done any of these things and the red light just stays on and won't boot. Only the fan works.
How to I reset the motherboard and start completely over,
There must be some way of reseting it that i don't know about.
https://linustechtips.com/topic/691494-intel-motherboard-problems/
You might have damaged the CPU
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
21 minutes ago, napier1999 said:
i didn't know before, i'm a newbie. I have also tried to remove battery and the light is still on, I will try to remove the cpu and try another, it maybe that the cpu is not compatable, but it is compatable in a listing i have found.
Read the manual to figure out what the led is telling you, usually a red led is warning you of a problem.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
