So I've had my PC for a while and I recently just upgraded to a Corsair H60 AIO Cooler to replace the stock Intel cooler. I'm not really looking to change (orientation) any of my case fans. So including the radiator, I would have two intake fans in the front and one intake in the back (radiator) and then two exhaust at the top. Thoughts? I have the Rosewill Nautilus if that means anything
https://linustechtips.com/topic/690951-fans/
On 11/14/2016 at 6:05 PM, nokre8 said:
The manual states that it is best to have the radiator fan as an intake which makes sense to me because wouldnt i want cool air going through it
What are your specs and how is your cooling currently oriented?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/690951-fans/#findComment-8875440
