Does the PS4 pro support 4K? I know that the marketing is around 4K and I know that sometimes games are run on lower res for better performance.
But what about other media: built in apps like Youtube or if I want to watch something from a disk or USB. Do these applications support 4K?
So if I load a 4K movie on a disk or USB will it be displayed in 4K native or does the PlayStation pro do some "magic" with it? Also, Youtube supports 4K in a browser, does that apply to the console?
https://linustechtips.com/topic/690152-ps4-pro-4k-output/
The netflix app on PS4 pro supports 4k so the youtube app probably will as well.
Unlike the Xbox One S, the PS4 pro does NOT support 4K blu-rays.
Most games will not run on 4K but will be upscaled (which is expected as the PS4 couldnt even run 1080p in most AAA games and the Pro is "just" ~2.5x while 4K is 4x the amount of pixels of 1080p).
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/690152-ps4-pro-4k-output/#findComment-8853910
Ok, so in short:
Games: if it can handle
Disk: NO
USB: YES
Apps: YES, if the developer supports it
correct?
https://linustechtips.com/topic/690152-ps4-pro-4k-output/#findComment-8853935
6 minutes ago, InfinityCaptain said:
Ok, so in short:
Disk: NO
USB: YES
correct?
Not sure on USB, rest is correct.
https://linustechtips.com/topic/690152-ps4-pro-4k-output/#findComment-8853950
