I have few question about my future plan build, I don't really want to buy ATX powersuppy for this thing as the power usages is quite low, I should able to get away from running external power supply right? I saw on some forums/video using like adapter that can convert the power to 24pin 4+4pin etc what do call this? I presume there should be tones of these on ebay etc. Would this Pfsense enough to run ~3 VPN client max and snort and intrusion detection and maybe caching on later date when I buy an SSD as i think hard drive im going to use is probs going to die soon.
I saw there is only one PCI x16 slot on the motherboard so meaning i can run one these 4 port nics right?
Current Build
ASRock N3050M Celeron Onboard BGA1170 Micro-ATX Motherboard
4 or 8GB ram
4 PORT INTEL NIC 49Y4242 49Y4241
Case: Custom
Magical Pineapples
https://linustechtips.com/topic/689946-pfsense-build-question/
