Hello,
I am about to start ordering parts for my first PC but have decided to reconsider my case. I was going to go for the NZXT S340 Red/Black. I am considering the Corsair Spec-Alpha but I'm not sure. As I've said this is my first build. I'd like good airflow and to be relatively easy to build in. My theme is red and black
Build: http://pcpartpicker.com/list/2PQ97h
Thanks!
https://linustechtips.com/topic/689786-case-trouble/
the corsair's one has a max height of 156mm and you cpu cooler is 159mm. so it won't fit in the corsair, but it will in the nzxt (161mm cpu cooler clearance)
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/689786-case-trouble/#findComment-8850359
20 minutes ago, TheBloodedEagle said:
Hello,
Thanks!
I would go with aio cooler and make build preattier u find good one under 50 and your build will look cleaner and with glass it will bea awesome. and then u can go even with the corsair
https://linustechtips.com/topic/689786-case-trouble/#findComment-8850418
Any AIO you find that cheap isn't worth buying, might as well buy a low tier air cooler, since a 120/140mm rad just doesn't perform well at all
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/689786-case-trouble/#findComment-8857516
