Hello, What should i do if the C: Reads the storage wrong ? How do i delete files if they arent files to delete.. ?
PS: They fall very quickly to -100mb , most of them after those in the image ( Apps & Games) So , really makes no sense , how is 110+ gb , on my ssd.. or is it restricted/reserved.. if so .. how to delete it .. or to unreserved it.
Gyazo Images:
https://gyazo.com/2c5953da612c8d87eb7c4e1bb8f8551a
https://gyazo.com/6969cdcbfc71c16eb760e736819a71ef
Thank you in advance!
https://linustechtips.com/topic/689345-c-partition-wrong-storage-reading/
Also i want to add that . sometimes i check the files , manually. by selecting bunch of folders to check their size... and still sometimes they show 19gb , i open the director , then i see is empty , to go back , recheck  , and says 0bytes / low amount ( is it retarded) ?  :))  (Sorry for the expression)
You can uninstall software and games with Uninstall software tool with Control Panel. That removes most of the files. Then you can use CCleaner or similar to clean anything left behind. Or if you are wondering why the two menus read different file size, the bigger number counts in save and profile files.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
