Hi Guys,
I am wonder if this is a good first build, the components are:
Intel Core i5 6600
Thermaltake Black Versa H24 Mid Tower Chassis
Corsair CS650M Modular 80 Plus Gold Power Supply
Corsair Vengeance LPX CMK16GX4M2A2133C13 16GB (2x8GB) DDR4 Black
Kingston SSDNow UV400 120GB SSD
ASUS H170 Pro Motherboard
Gigabyte GeForce GTX 1060 WindForce OC 6GB
Deepcool XFAN 120mm Case Fan
Hopefully I am not missing any components or having incomparable parts (that would suck for building a PC) or have some bottle necking going on. Please recommend any things should changes that should be made so that it is better :D
Also, i am on a budget, around 1200 AUD Dollars :(
Thanks
https://linustechtips.com/topic/689316-building-first-pc-please-help/
It looks good to me. Do you know how to physically build a computer?
Discord: Skyline#0820
Literally an idiot, don't listen to me.
Main computer: i5-4690k 4.3GHz, Noctua NH-D15, Nitro+ RX 580 SE, 16GB Corsair Vengeance, Samsung 840 series 128GB Crucial MX500 2TB, WD Purple 3TB, EVGA 600w, Dell s2240m 1080p 60hz, Corsair K70 Cherry MX Blue, Logitech G502 Hero.
Asus GU501gm
Just now, Jo129845 said:
yes
OK, what games are you going to be playing?
Asus GU501gm
games like Dota 2 and CS:GO
Ok, you don't really need much to play those games. If you plan on playing other games you don't need to worry about the specs.
Asus GU501gm
1 minute ago, Jo129845 said:
would it make any difference if i save a few extra dollars and went for the i5 6500?
Bottle-necking won't be a problem for you, you can go with a 6500 if you want to save a little. If you compare it to a 5700hq on cpuboss.com, its basically the same as a 6500. I have a 5700hq in my laptop and its plenty for me.
Asus GU501gm
And if you wanted to save another 20$ USD then you could get a 6400.
Asus GU501gm
I feel like GTX 1060 isn't powerful now, seeing the CPU can downgrade that much without bottle necking.
Can you give me examples of games i would not be able to run at an appropriate fps
I don't really know any that you couldn't run. I have a gtx 970m and I'm starting to notice it isn't powerful enough anymore. The 1060 is as powerful as a 970, so you could technically run 1440p at lower settings if you wanted. All the cpu has to do it put the frames on the monitor, it doesn't have to do as much work as the GPU unless the game requires lots of non-graphics processing. Watch JayzTwoCents video about bottle-necking.
Asus GU501gm
A. It's significantly faster than a DESKTOP 970 and very close to a 980
B. Desktop 970 is ~70% faster than a 970M
Therefore, your logic is terrible...
1060 6GB can run most games at 4K high-ultra at 30+ frames, at 1080p very high-ultra its 99.99% of the time over 60 frames in pretty much any game.
I would get a 6500 and use the extra money for a NZXT S340.
Also swap the GPU for a EVGA, ASUS, or MSI card as Gigabyte cards tend to have bad PCBs and components.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
