Virtualization issue
Solved by SLAYR,
14 minutes ago, XxDestructorxX said:i want to do different stuff on each of the 3 vm's and when i want to play or do something can i switch some how to 1 os or vm'
cause i have 3 monitors and want to make it into one desktop experience instead of having 3 completely different vm'si
Add another hdd with windows on it, and then when you restart the computer choose to boot from whatever drive you want, you don't need to reinstall anything.
