I have a problem.
I have a drive that I use to store games, phone backups, and pictures on. Today I wanted to back up my phone and when I plugged the drive in it didn't show up in file explorer. I went into device manager and saw that it was listed under storage devices but I tried to update the driver for it and nothing changed. I took the time to boot into my second OS, Ubuntu, and it didn't show up there too. Does anyone know what the hell is going on?
https://linustechtips.com/topic/689065-wd-drive-issues/
1 minute ago, deXxterlab97 said:
see if drive is dead
Should he go over the biological defintion or "parameters" that make something alive?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843173
1 minute ago, brodieslee said:
I can feel the drive moving when i touch it
That's what she said?
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843178
5 hours ago, brodieslee said:
deXxterlab97, I can feel the drive moving when i touch it
sounds like a song title
next time use @deXxterlab97 thanks for capitalizing the X there, appreciate
No I mean still run the software, it could move but it could be dead too.
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843187
Just now, deXxterlab97 said:
quote people so they know. hmm that's weird
The drive likely lost it's drive letter due to a flash drive or SATA cable.
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843243
@Captain_WD would know about this. He's an expert on hard disks drives!
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843762
~snip~
Hi there :)
I'm sorry to hear about the situation. Could you specify the drive's model, what system are you using to access it and if you've tried some troubleshooting steps?
Could you post a screenshot of the S.M.A.R.T. data that you have checked?
Also, I would suggest trying another cable and trying the drive on multiple ports and multiple computers to see if you have access to it.
I'd recommend running WD Data Lifeguard Diagnostic and see if the drive is detected and if it passes both the quick and the extended tests.
Let me know how this goes and we will continue from there. :)
Thanks @Xanthe_2871 for the mention!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843981
Here's a possible solution that fixes a certin bug that prevents hard disk drives from showing up in Windows:
Go to Administrative Tools (you can type this into the search bar and it will come up, otherwise it's in Control Panel > System and Security > Administrative Tools); there, run Windows Memory Diagnostic, let it restrart the PC and do its thing.
Once the PC boots back into the Desktop, the drive should (maybe) show up in File explorer again.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/689065-wd-drive-issues/#findComment-8843988
