PS4 + PC Same output?
There are switches too but why not just plug them into the TV/monitor? Or is that not shared by the two?
You should know that this kind of a switch is a very simple device. Literally it only need the connectors, the switch, the wires to connect it all and a plastic box. Don't pay anything above $20 for it unless it has some functionality like a remote control. Even then it's a bit on the high side. Here's one: http://www.amazon.com/Speaker-Headset-Switching-Manhattan-172851/dp/B000K8PH8C/ref=sr_1_2
https://linustechtips.com/topic/688980-ps4-pc-same-output/#findComment-8842278
19 hours ago, NeoZeon said:
is it a usb hedset/mic?
Headphones are 1/4 aux cable, Microphone is usb.
The monitor doesnt have any sound output
https://linustechtips.com/topic/688980-ps4-pc-same-output/#findComment-8845880
