Basically, I have a 3.5mm jack splitter that splits the one port on my MOBO and lets it connect to both my HyperX Cloud Stinger headset, and my speakers. however, when I change the volume on the headset, it somehow alters the volume of the speakers. how can this happen, and how can I fix it?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/688875-strange-volume-fluctuations/
Its probably changing the volume one the OS itself
It's not. i checked.
as far as I can tell, what the volume slider on my headphones does is amplify the audio using it's own AMP. maybe something to do with impedance or something?
Laptop:
No , I impedance has do do with the physical drivers for the headphones . it wouldn't effect the speakers.
  • 2 weeks later...
bump
Laptop:
