Intel I7 6700K Heating Issue
Go to solution Solved by Zyndo,
1 hour ago, Faizan Shaikh said:
Snip
well in reference to (1), stock settings can cause MASSIVE temperature fluctuations in skylake. I don't know about 78C immedietely as i have an AIO and those take a bit to warm up, but yes you can get very spikey temperatures on stock settings. I would recommend setting a manual voltage/clock setting (something like 4.0 @ 1.21v or something like that) and see if you still experience such high/fast temperature jumps.
Hello Guyz,
Finally I've managed to buy I7 6700K with ASUS Z170 Pro gaming motherboard. It's Decent board and processor. but I'm facing unprecedented Over Heating issue.
The issue is when I'm doing general Stuff it's my CPU temperature remains about 30C which is good. but when I stress cpu using cpuz or other benchmark application It raises CPU temperature to 78, to 78C within a second
and when I stop stress test it back to normal around 30C. I Don't know what exactly the problem is. Please Help me In regard.
I'm Attaching Screen Shot of Stress test with compare to time.
https://linustechtips.com/topic/688136-intel-i7-6700k-heating-issue/
1 minute ago, Faizan Shaikh said:
Hello Guyz,
What's it being cooled by?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
78 is fine.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Just now, Faizan Shaikh said:
It's cooled by Cooler Master Hyper 212X
Temps are still pretty high even with that cooler. Have you tried reinstalling the cooler or adding new thermal paste?
Sounds like you might want to reapply thermal paste. My hyper T4 doesn't let it a 6700k get that hot unless its on intel burn test...
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
yeah I did that but unfortunately not worked.
How fast is the fan spinning when it's at that temp? Not much else I can say other than try another cooler.
I know this is a stupid question but, Are the fans spinning?
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
17 minutes ago, Faizan Shaikh said:
Snip
I have a 6700k and have a few questions for you.
1. what settings are you running on the 6700k? stock settings have been known to SERIOUSLY overuse the voltage when under load/fluctuating loads. my CPU actually runs cooler (when measured by peak temperatures) when set to 1.36V and 4.6GHz overclock than when compared to stock settings. 78C isn't unbearably hot for skylake anyway, and it would be fine if that was your peak temperature.
2. what kind of thermal paste are you using? Some thermal pastes require a 'burn-in' or a cure time before they begin functioning properly. also, make sure you have enough thermal paste covering the majority of your CPU's IHS. contrary to the popular belief, over-application of thermal paste typically does not insulate your CPU (resulting in higher temperatures), but having slightly not enough can definitely cause issues. Also recycling thermal paste that has already been used on a previous mount can sometimes be problematic, so apply a fresh coat of thermal paste if you have done this.
3. Make sure your CPU heatsink is seated properly and secured firmly to your board. a loose or bad seat on a CPU heatsink could easily cause spiky temperatures. Also, if your 212X comes with a plastic sleeve on the baseplate, make sure that has been removed.
1. I'm using 6700K to stock settings and it's optimized automatically by ASUS 5 way optimization. yeah it's bearable when peak temperature is 78C but is it fine if it take a second to raise 30 to 78?
2.I'm using stock thermal past comes with Cooler Master Hyper 212x. and I've also applied enough from it & it doesn't insulating CPU. and I've also reapplied fresh coat of thermal past.
3. yeah it is.
Snip
okya I'll try that. does water cooler makes any difference?
well the liquid in a water cooling can give you a sort of temporary "buffer" while the liquid itself heats up so it would result is less severe sudden temperature spikes when compared to a simple heatsink cooler.
okay. so is there any chance of CPU manufacture defect i.e. can cause heats up imminently?
