To start, I have a 2tb and 1tb hard drive. Not full but partially used. I have a Samsung 950 PRO series NVME drive (500gb). For my OS and all, it's near full.
I'm looking to buy another SSD, but I want to combine it with my NVME drive to make a single drive. I'm planning to later use those two hard drives for another use, so in the end I'll have a single drive made up of those two SSDs.
How can I achieve this without loosing any of my data from my NVME drive? I'm afraid to copy everything over and all.
If I cant do that, how can I use that SSD as a second drive most effectively? Meaning, having some programs in that drive and files there while still having it as easily accessible as possible. I don't want to have to go to that drive and deal with the two so separately, that would get annoying.
https://linustechtips.com/topic/688032-help-with-multiple-drives/
You're going to lose so much speed if you put them in RAID.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Just now, alexly123 said:
Well I don't want to strife them
I want to add the drive to the end, so once I'm out of the nvme storage ill go to the ssd
that's what JBOD (just a bunch of disks) is. you can combine drives together.
idk
more import question is why don't you more some data to the other drives? Games you don't play as much you can move leaving most played games on the ssd.
I would suggest moving my doc, pic to another drive as well as your download folder.
you can install programs to other locations than c if you which just custom install and change the location.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
2 minutes ago, alexly123 said:
Because I have only a few games on that drive and most of my programs I want at a faster speed. I wont be using those drives for long
so you have all of your data music and such all on the ssd?
tbh you will probably be better storing your important files somewhere then setting up the SSDs in raid 0
second vorticalbox
good future planning on drive space is essential,
my example:
1x250gb ssd OS and Progs
1x250gb ssd games
1x3tb hdd data ,downloads,pics,mu downloads,movies......virtually everything that doesn't have to be read super fast
while my games drive is getting full others are OK
as for bootable raid 0 nvme's , I don't  know if this is possible(google check to see if its been done with your mobo) and if it was "yes" data would have to be cloned off the drive (if nvme is boot device) else copied to new drive and this set as boot device until raid created.
