4 minutes ago, deXxterlab97 said:
Temps? Usage?
also resolution?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831057
Settings in game?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831059
1 minute ago, Wicked Jester said:
Ok so I'm on the lowest settings at 1080p. It looks like my card is onlyreaching 700MHz for some reason
Temps on card?
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831079
It doesn't have to work as hard to accomplish its workload. Pump the graphics up a bit.
What are your temps?
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831083
still should be well over 60FPS. It's not like the 6600K is a  major bottleneck here
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831109
Im pretty sure it should be over 700mhz to run bf1. lol. temps look ok at 65-70max
If it's at 700Mhz, I would use DDU and reinstall drivers. What's your res scaling at? 50% at 1080 is 1080 while 100% is 2160 downscaling.
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831119
100% at 1080p is 1080p - 50% is 720p - 200% is 4K
100% at 2160p is 2160p - 50% is 1080p - 200% is 8K
BF1 Launch - onwards....Res Scale has been fixed, the 42% was a BETA issue, and since the beta ended, this has not returned.
TL:DR - DO NOT USE RES SCALE 50% ^Read above
It's likely the 700Mhz locked frequency is causing his low performance,... and a DDU clean sweep of Nvidia Drivers +> Driver Reinstall should fix that.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8831843
This is NOT  a driver, hardware or configuration issue of any kind. This is a bug within BF1.
https://www.reddit.com/r/Battlefield/comments/58pm6y/bf1_can_we_have_a_visible_thread_about_cpu_usage/
You can try the  maxvariable fps fix and setting the bf1 process to high priority. It helped me a bit.
I hope DICE fixes this issue soon.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8832204
Hopefully they do. They're adding fuel to a fire that shouldn't be burning.
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8832268
It is.
https://forums.battlefield.com/en-us/discussion/19282/battlefield-1-minimum-pc-requirements#latest
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8834772
Ok. So it turns out that After reinstalling the drivers and using evga precisions K boost to ensure my card was running at the correct speed. I did see quite a performance increase. Playing on high at 60fps. Still I think BF! could use some optimizing. But it's fixed for the most part.
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8843388
Should be able to play 60FPS Ultra on a 1060... it can go over 67 even on 1440p and your CPU shouldn't throttle it from the 90s to 60s or lower on high vs Ultra... there is definitely still a problem somewhere
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8844596
I know theres a problem still but I dont know what it is. I just managed to get it playable
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8846578
:C
I would still try and find the problem. At least it works tho
btw not trying to hate or anything just trying to help you realize that your rig isn't performing as well as it should for whatever reason
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8847027
49 minutes ago, Shiv78 said:
:C
I never accused you of, or thought you were doing anything other than helping. Thank you. I will continue to try to figure it out. I'm just not sure where to start
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8847326
This might get you better performance doesn't explain ehy you were getting such low clock speeds but seems you fixed that.
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8849919
39 minutes ago, Wicked Jester said:
Ok so my issue is fixed now. It was actually a windows update that had failed to install properly
lol
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/688013-bf-fps-issue/#findComment-8858055
