Antivirius Help
Go to solution Solved by Slottr,
Windows defender and Malware Bytes mix. Get the premium subscription when its on sale for like 10-15 bucks. Well worth it.
So I currently use the free windows defender antivirus. I want a better one, but I don't want to pay for it. I tried Avast and it slowed down my computer and a lot of it's features required money. Does anybody know of a decent Antivirus program that's free, works well, and doesn't slow down my computer too much?
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/687996-antivirius-help/
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8830864
ESET antivirus is good, but it's paid antivirus
i'm using bitdefender at the moment, from this humble bundle https://www.humblebundle.com/lifehacker-software-bundle i just got it though, so i can't vouch how it'll perform in the long run
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8830870
This is exactly what I use. That said, I'm a technician, and know how to avoid bad stuff on the internet, so you might still want an AV suite.
MBAM Premium is well worth the money and great at preventing unknown exploits in the wild, but does not replace a good AV Suite.
AVIRA is what I've started to recommend as a FREE AV Suite since Avast announced they may be purchasing AVG.
Otherwise, I wholeheartedly recommend paying for Kaspersky or ESET Node32 if you want the best protection with decent support.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8830878
https://www.comodo.com/home/internet-security/free-internet-security.php
Requires a little configuring and then you have the best overall free protection available.
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8830924
Thanks for all the help everybody! :)
My Rig
 Peripherals
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8831078
Thought I would add my own opinion.  Windows Defender is fine, but if you want a good free antivirus use Sophos Home.  In the end, antivirus is always going to be useless unless you actually need it.  And most of the time you don't need it, Windows Defender is fine, it runs scheduled scans automatically I beileve.  If you configure malwarebytes to run scheduled scans or something else, it's up to you, then that is more than enough.
You should be less worried about standard malware anyway, and more worried about exploits, they are more common and also have more access to your system usually depending on the exploitation method, and the payload.  I suggest using Emet, it's free. https://www.microsoft.com/en-nz/download/details.aspx?id=50766   and use a browser like Chrome, Firefox or Edge because they have protection included.  Make sure to stay off dodgy sites, if you are really worried use a sandbox like Sandboxie.
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8832653
Just build that wall. Keep the viruses out of your computer.
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
https://linustechtips.com/topic/687996-antivirius-help/#findComment-8832791
