I've got an Evga Gtx 1070 and it's idling at 45 celcius, which I'm not too happy with. It's like this because the fans are off when it's not in use. But I'd like to slightly edit the fan curve so that the fan starts a bit earlier to keep it in the lower 40's since Summer's coming soon. How would I go about editing the curve? I have Msi Afterburner, but I've never edited a fan curve, let alone know how to do it effectively.
Nothing.
https://linustechtips.com/topic/687928-editing-fan-curve/
Experiment. Get it as fast as you can without it being annoying at idle, then ramp it up at about 65C and 100% at 75C.
That's how I do my Rad fans and GPUs.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/687928-editing-fan-curve/#findComment-8830063
You can edit the fan curves from the MSI Afterburners setting in there go to fans and enable user defined thing. After that you can make your own fan curves.
https://linustechtips.com/topic/687928-editing-fan-curve/#findComment-8830075
45c is more than fine...i posted this today:
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/687928-editing-fan-curve/#findComment-8830275
The issue with the EVGA cards is not the GPU chip being too hot, but the VRM and VRAM being too hot. The GPU temperature sensor only measures the GPU chip, and not the VRM or VRAM. So, the GPU chip could be pretty cool, while the other parts are dangerously hot.
If you have an EVGA card, it's important to both install the new BIOS for your particular model: http://forums.evga.com/Update-11816-with-NEW-BIOS-EVGA-GeForce-GTX-108010701060-PWM-Temperature-Upadate-m2573491.aspx
And also to order (they're free) and install new thermal pads: http://www.evga.com/thermalmod
If you aren't comfortable with installing the thermal pads yourself, then you can RMA your graphics card to EVGA, and they'll send you a card that has thermal pads already installed.
EVGA is down-playing the issue, but the number of people who are experiencing worsening artifacting from overheating VRAM is increasing. And for those who aren't experiencing visible issues just yet, if their VRAM has been running at excessively hot levels, then there is significant wear on their GPU, and a reduction in its durability.
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
https://linustechtips.com/topic/687928-editing-fan-curve/#findComment-8834048
2 hours ago, TheSuspect said:
87c lmao. Anyway, thanks
yeah, and like i said: all 8 of them we have are all running that hot for 6 years straight, 24/7 for the most part, and none of them have failed or shown any problems...so, your brand new GTX 1070, idling at 45c...probably only a few hours a day...you know :P
They are all designed like this...my 980ti strix idle at around 49-50c and it's all good as well...EVGA, ASUS MSI...they woudln't do that kind of stuff if it was to arm the hardware in any ways, they are responsible for warranty and customer services and stuff...
https://linustechtips.com/topic/687928-editing-fan-curve/#findComment-8834482
