This isnt a problem just something im curious about. I have an i5 4460 that clocks at 3.20ghz. its a locked processor.
While i was transferring files today the CPU was at 25% utilization and task manager jumped up to 3.23ghz.
I was just curious whether it was task manager just being inaccurate or if in fact my CPU was running a little faster than i typically is supposed to.
Thanks in advance.
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/687907-cpu-clock-speed/
The 4460 turbo boosts up to 3.4ghz.
The task manager is also known to not be an accurate way to read your clock speed but that may or may not have been fixed by now.
Moved to CPUs, Motherboards, and Memory.
https://linustechtips.com/topic/687907-cpu-clock-speed/#findComment-8829795
my cpu runs at 4.4GHZ but task manager shows 3.5
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/687907-cpu-clock-speed/#findComment-8829828
13 hours ago, CookieMaster said:
~Snip~
13 hours ago, EminentSun said:
~Snip~
13 hours ago, WoodenMarker said:
~Snip~
13 hours ago, KOMTechAndGaming said:
~Snip~
13 hours ago, wrathoftheturkey said:
~Snip~
12 hours ago, TheSuspect said:
~Snip~
Thank you all for taking the time to respond. i learned some things. thank you
https://linustechtips.com/topic/687907-cpu-clock-speed/#findComment-8833378
