5 minutes ago, CookieMaster said:
To include manufacturers didn't add OC support for non k series until recently.
You do realize that the chip in particular is 11 years old, and way before any z, or k anything.
5 minutes ago, Viesulis said:
i found some ppl getting it to 4.5ghz
If you only have a cheap loop that pentium will run really hot , and may not be able to keep up.
It should be able to OC on any non oem lga 775 board.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/687898-school-project/#findComment-8829674
Just now, SLAYR said:
You do realize that the chip in particular is 12 years old, and way before any z, or k anything.
If I'm looking at the right cpu its only 6 years old
https://linustechtips.com/topic/687898-school-project/#findComment-8829691
http://ark.intel.com/m/products/27520/Intel-Pentium-D-Processor-945-4M-Cache-3_40-GHz-800-MHz-FSB
1 minute ago, SCHISCHKA said:
I'm prettier sure the D was the hottest CPU ever manufactured
Go look up the fx 9590, 220W tdp cpu.
https://linustechtips.com/topic/687898-school-project/#findComment-8829705
2 minutes ago, SLAYR said:
Hottest. FX-9590s have some of the highest TDPs, but can run relatively cool for what it is.
Pentium Ds in general are very bitchy and do run hot.
https://linustechtips.com/topic/687898-school-project/#findComment-8829730
Back then it wasn't as much about K vs non-K and OC support vs no OC support. Overclocking simply wasn't officially supported. We pushed all CPUs and killed a lot of them in the process. Rumormills spat out insider info about specially clockable steppings and people imported and pre-overclocked them in bulk.
OP, you should  look into boards with Intel P45. Something along the lines of Asus P5Q Deluxe if you can find one. Don't skimp on the RAM either. It used to make a real difference in OC. And don't overlook broken boards. The caps are gonna be bulging in a board this old so you're going to have to solder new ones on.
https://linustechtips.com/topic/687898-school-project/#findComment-8829751
Yea they didn't have the same power saving and frequency adjusting features as a modern CPU. I remember them as always blowing hot air, my FX in comparison runs quiet at idle
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/687898-school-project/#findComment-8829753
Read my comment above also, made a mistake thinking the cpu was 6 years old and not 10
https://linustechtips.com/topic/687898-school-project/#findComment-8829761
