Hi,
I'm planning on building a new computer in the next few months and was just after some advice or feedback. This is my first build so I thought I'd get a bit of help!
Hopefully this post doesn't get too long!
Aim
I just finished a design course as part of high school and during that course I used lots of Adobe products like Photoshop, Illustrator and After Effects. I also used 3D modelling programs as part of the course. I see myself using these programs a lot in my future, so a machine that handles those kinds of programs well would be awesome!
I intend to use it for light gaming as well, but I am aware that workstation computers can have difficulties when it comes to gaming. Professional performance is more important than gaming performance, however both would be appreciated.
I don't intend to overclock, however I might get an unlocked processor just in case I want to one day, you never know!
Location and Budget
I live in Melbourne, Australia, and I intend to buy my components from PC Case Gear. However, if there is a component that you guys think I'll need I'm happy to shop in other places too.
When I began planning this build I tried to focus on parts that were cheaper, but as I have put more thought into this I've decided I'd rather spend more money on a quality machine which will last longer, with plenty of room for upgrading in the future. Thus if there is a component that you think would be really worth having, I'm happy to save up and get that. In general I'd like to spend less than $3000
Monitors and Peripherals
My current computer has a HDMI port and I use a flat screen TV as a monitor and it has done a good job so far, however I do intend to get another 2 monitors to go on either side of it but these are something I'm happy to save up for later.
I think I have all of the peripherals that I need. A copy of Windows 8 will be needed though.
Reasons for Upgrading
The computer I have right now is just a pre-built machine that I picked up for about $200 from Officeworks. While it's done well through high school, I want a machine that is more capable of using programs like Autodesk 3DS Max, CAD programs and Adobe for use as I go into university and perhaps a career in design/engineering.
I've been investigating parts and stuff for a while now, and I have a list. I'd really like to know what you all think and if there is any suggestion you can make I'll appreciate it so much!
Case:
Corsair Obsidian 650D Mid Tower Case
Motherboard:
Asus P9X79 Pro Motherboard (Socket 2011)
CPU:
Intel Core i7 4820K (Socket 2011)
CPU Cooling:
NZXT Kraken X60 AOI Liquid CPU Cooler (280mm)
Power Supply:
Corsair HX850 V2
Memory:
16GB G.Skill Ares F3-1866C10D-16GAB
(If I end up with a motherboard with support for more I will definitely buy more, however for budgeting reasons I'll buy more RAM at a later date when I've saved the money for it)
Optical Drive:
LG BH16NS40 16X BD-R Blu-Ray Writer (OEM)
Storage:
  • 1TB Seagate Barracuda
  • 60GB Corsair Force Series LS SSD
Graphics Card:
This is where I definitely need help!
I have looked at a number of graphics cards and am not sure whether to get a consumer card or whether I need to get a professional one. I like the idea of getting a professional card as I know I will definitely be using programs that will benefit from such a card, however they can be very expensive.
I was thinking maybe something like an AMD Firepro W7000 professional graphics card. It performs well on programs which I like to use according to benchmarks while also performing well on many graphics heavy games such as Crysis 2.
However I know that you can get cards with comparable specs for far less which are designed more for gaming PCs.
I'm really not sure which path to take!
Other stuff:
I know that professional builds shouldn't be about looks, however I was thinking of adding in some Bitfenix Alchemy lighting strips because I really like the effect.
Sorry this got a little bit long! If you have any advice or suggestions I'll really appreciate it!
Thank you so much!
https://linustechtips.com/topic/68780-workstation-build/
I would honestly wait until you are either in courses in uni that require it, or have a job that requires it. You certainly don't want to be kicking yourself later if you choose a different career path. Also, computer parts out-date relatively quickly. Buy what you need now. Just my two cents.
https://linustechtips.com/topic/68780-workstation-build/#findComment-943032
What content are you currently working on? Scale of work? Programs being used?
https://linustechtips.com/topic/68780-workstation-build/#findComment-943062
Fair enough. You're probably right.
However I do really enjoy tinkering around on these programs and even if they don't end up being a part of my career I will always enjoy making content using those programs.
Perhaps there are some cheaper non-workstation components which will allow me to still play around with those programs but still do well if I do enter the design/engineering industry?
Thanks for your feedback! I really didn't expect a reply so quickly!
https://linustechtips.com/topic/68780-workstation-build/#findComment-943065
There are definitely cheaper alternatives.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Btw, welcome to the forum. :)
https://linustechtips.com/topic/68780-workstation-build/#findComment-943073
I use Adobe CS6 products a fair amount, in particular Illustrator with some pieces having a really large number of paths (enough to make my current computer really struggle). These include Photoshop, After Effects, and InDesign. I have really just begun using 3DS Max recently, with my largest project being around 5000 polygons, however as I learn how to use the program more and are able to achieve some of my more ambitious ideas I can see that count increasing pretty fast. I would also like to use programs such as Autodesk Mudbox or ZBrush in the future.
I find creating my own content really satisfying, and even if this does not become my chosen career field, I would really love a computer that is capable of performing those kinds of tasks really well.
https://linustechtips.com/topic/68780-workstation-build/#findComment-943079
My recommendations: http://au.pcpartpicker.com/p/1SYsK
Ssd for OS, programs, and scratchdisk for Photoshop/etc. Unless the amount of time you use is precious and you make money depending on how fast you complete your work or you can't have an error mid-project or mid-render, the 7950 should be quite powerful enough to work on large projects just fine.
I am really new to forums, in fact this is the first time I have ever posted on one. This is probably an embarrassing question, but how do you tag a person in a post?
Yes, just like that.
There's also quote and multiquote if you want to tag one or more posts.
https://linustechtips.com/topic/68780-workstation-build/#findComment-943110
Thanks for your help @WoodenMarker!
I'll definitely take those suggestions on board!
Honestly I think anything'll be an improvement on the computer I have right now.
What I recommended should be quite adequate for anything I imagine you're doing until you start venturing into getting a 3930k/4930k.
https://linustechtips.com/topic/68780-workstation-build/#findComment-943129
Also using a TV as monitor .... :unsure:
I forgot about the display. Get two of these: http://au.pcpartpicker.com/part/asus-monitor-vs239hp
https://linustechtips.com/topic/68780-workstation-build/#findComment-943140
Please save yourself some money and get an Haswell i7 4770k and a Z77 board together with a consumer gpu ...
edit: or what @WoodenMarker said ;)
Yeah, I probably was moving a little too fast into products that didn't really fit my needs. Thank you for your fast advice guys.
As for the TV as a monitor situation, I know its not really best practice, but it was free and it works well for what I need it to do  :)
https://linustechtips.com/topic/68780-workstation-build/#findComment-943142
