Like the backlight is on but the screen is black?
https://linustechtips.com/topic/687304-samsung-tv-problem/#findComment-8823115
Just now, blackwargraymon said:
yes
Go into settings and turn energy saver mode off.
https://linustechtips.com/topic/687304-samsung-tv-problem/#findComment-8823144
1 minute ago, blackwargraymon said:
it was off already
Ok then try turning it on? Or turn it on and off again?
Also try unplugging the TV for a while and plugging it back in, and as a last resort try to find a "reset to factory settings" option.
From what I've found this is the only known way of fixing the issue, so if none of those options work you will need to contact samsung and do an RMA to get  replacement.
https://linustechtips.com/topic/687304-samsung-tv-problem/#findComment-8823174
ok thank you for the help
https://linustechtips.com/topic/687304-samsung-tv-problem/#findComment-8823183
