Hello everyone on the forum, I have an ek 360mm predator radiator for my cpu, and it has a thingy so that it can attach something more, i want to watercool my gpu also, but im not sure what parts to buy that fits with the radiator i already have, also i want to buy the same brand if possible, and also if possible, to have it assembled upon purchasing a new gpu, or maybe tips on how to do it myself safely without messing up my gpu.
currently i have a 980 ti (msi) but i want to get a 1080 (or 1080 ti when that comes out) however for now i need to figure out what watercooling block to buy for my gpu that will work with the radiator i have for my cpu, so i wont need a seperate radiator (if possible). please reply with good ideas. money isnt an issue, this is something i need to have to keep it cool in the future.
https://linustechtips.com/topic/687230-need-help-with-watercooling-gpu/
Just order the block from ek prefilled for the specific gpu you want. Can't tell you what block to get without first knowing exactly what card.
