Storage capacity reduced.
Solved by Guest,
2 minutes ago, 19_blackie_73 said:Well i guess you only have a single hdd in your pc. If you add up c: d: and e: you have your 1tb capacity.
This is called partitioning
Adding up them numbers got me to 853-ish gb. Way off from 1 tb...
He also said he had an SSD somewhere. So one of them C/D/E drives, is the SSD, so even less then 1 tb...
I think he has some unpartitioned space on this 1 tb drive.
