So odd issue... Running 2 gtx 970s in sli using a 3way bridge for 2 cards spaced apart and tried this with a single bridge. when I pUT the cards in the slots that only allow for x8 x8 I get full working sli...when I put them in the slot for 16x 16x  theyou both aRe detected and run at 16x but the sli bridge is not detected???? I know I would only gain between 0 and 5 fps from one to the other but I have 16x so I kinda wanna use it....help
https://linustechtips.com/topic/687172-odd-sli-issue/
U have to have the cards in slots one and two on the bridge dude
if u leave space 2 empty to crest space between the cards even if ur Mobo supports it the bridge won't work
there for won't be detected
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/687172-odd-sli-issue/#findComment-8821797
