My computer won't recognise anything I plug into the USB 3.0 I have a 990fxa ud3 and when I plug my mouse in the led comes on so there is power but nothing happens
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/68676-usb-30-not-working/
Driversdriversdriversdrivers
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941289
Do your windows updates to get the drives all sorted.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941295
Is that service lack one ? Or
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941305
You need the proper drivers, oddly enough only the usb 3.0 ports work while im in linux.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941306
Type windows update into search bar, and do all teh updatez
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941309
Ok doing them now
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941325
report back trooper
dont die on us now
Got loads to do so taking time
https://linustechtips.com/topic/68676-usb-30-not-working/#findComment-941381
