1 minute ago, Sbuqaarah said:
http://pcpartpicker.com/list/LKqkjc
Any recomendation for a monitor.
Thanks <3
What is your budget and are you a content creator (create videos and stuff like that) or are you just a typical gamer?
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816337
budget?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816349
Just now, Sbuqaarah said:
gaming and light photoshop and dreamwaver
I'd suggest you save some money and get a i7-6700K and a Z170 motherboard instead. For monitors, I'm still looking, so hold on. :)
My Daily Driver:
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816352
no limit
http://www.lg.com/us/monitors/lg-38UC99-W-ultrawide-monitor
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816359
Just now, Oswin said:
That's bloody expensive, @Oswin ^_^
My Daily Driver:
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816362
He did say no limit. that monitor is beast
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816365
thanks looks Sexy :x
I'd suggest this monitor: LG 34UM94-P :)
My Daily Driver:
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816374
did linus make a review about it ?
I dont think so. but techsource did
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816375
I see that the ultrawides have caught your attention. Perhaps check out the Asus ROG PG348Q if you're looking for something more gaming focused? http://www.newegg.com/Product/Product.aspx?Item=N82E16824236717&cm_re=34_inch_rog_ultrawide-_-24-236-717-_-Product
Video;
Article; http://www.guru3d.com/articles-pages/asus-rog-swift-pg348q-curved-gsync-monitor-review,1.html
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816603
May I also ask why you chose the Asus Ramage V Edition? It's a rather overkill motherboard, especially when paired with a dinky 850 Evo. Might I suggest a bump "down", if you could call it that, to the Asus X99-Deluxe, and a bump up to a 512GB 960 Pro NVMe drive?  NVMe drives are a serious upgrade over regular SSDs.
http://pcpartpicker.com/list/bZr7vV
(The 950 is a placeholder as PPP hasn't update their db yet is seems, still a similar price though)
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8816634
Never thought of that thanks
https://linustechtips.com/topic/686659-pc-build-plan/#findComment-8817076
