Restore USB from weird state
Go to solution Solved by NunoLava1998,
Repartitioned using GParted as it was available. One unexistent copy that Manjaro loves to make, and the real USB! Finally, i was spending 5 hours on this.
After a KDE crash during a upgrade, somehow my 16 GB USB was likely corrupted. Now Manjaro Linux 16.10 thinks i have 2 USB sticks, one that gives signs that usually means the kernel is going crazy or that your USB is broken, as you can't mount or format it.
I installed Archbang on one of them (the only USB that you could manage) and booted from it. And behold... a blinking cursor.
How can i restore this?
(please reply fast)
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/686235-restore-usb-from-weird-state/
5 minutes ago, Electronics Wizardy said:
Is there data on it you care about?
You can just reformat it.
when i try to reformat the working partition and install anything on it nothing works when booting like if nothing was installed
when i try sdb5 (which changed to sdf5) which is the unusuable...
"not enough blocks" or "too many blocks"
gdisk /dev/sdb
hit
o
n
ENTER
ENTER
ENTER
ENTER
ENTER
w
then mkfs.ext4 /dev/sdb1
Just now, wrathoftheturkey said:
Ten to one it's broken. USB drives tend to break really damn easily
It seems Manjaro just tried to recreate sdf1 and made sdf5, but again, couldn't sdf5 be the USB and sdf1 be that stupid CD that shows up when you plug it in for "encryption and security and works on windows and mac and linux even though it only works on windows to be real"?
But sdf5 seems to be dissapearing like Manjaro regret it. Maybe i didn't install Arch correctly, meh.
1 minute ago, Electronics Wizardy said:
gdisk /dev/sdb
hit
o
n
ENTER
ENTER
ENTER
ENTER
ENTER
w
Warning! Main partition table overlaps the first partition by 34 blocks!
You will need to delete this partition or resize it in another utility.
Aborting write of new partition table.
dd if=/dev/zer of=/dev/sdb
this will clear all the data on it, then try again
dev/zero
seems legit
EDIT: did it
not doing anything
looks like sdf5 is indeed a imaginary partition, lol
did zero on sdb1
4 GB... um
i am PRETTY sure it's 16GB, not 4GB
unless this is running in 32 bit mode, but this surpassed the 32 bit limit
EDIT: now the unusuable part can be accessed easily, i'm just not allowed to mount it, but sudo is love
Kernel messages from USB disconnecting and connecting:
[ 4902.288285] usb 3-5: new high-speed USB device number 10 using xhci_hcd
[ 4907.301655] usb 3-5: device descriptor read/8, error -110
[ 4912.418340] usb 3-5: device descriptor read/8, error -110
[ 4912.521662] usb usb3-port5: unable to enumerate USB device
[ 4995.648630] usb 3-5: new high-speed USB device number 11 using xhci_hcd
[ 4996.068630] usb 3-5: new full-speed USB device number 12 using xhci_hcd
[ 4996.228663] usb 3-5: device descriptor read/64, error -71
[ 4996.491981] usb 3-5: device descriptor read/64, error -71
[ 4996.755279] usb 3-5: new full-speed USB device number 13 using xhci_hcd
[ 4996.915306] usb 3-5: device descriptor read/64, error -71
[ 4997.178682] usb 3-5: device descriptor read/64, error -71
[ 4997.441953] usb 3-5: new full-speed USB device number 14 using xhci_hcd
[ 4997.442081] usb 3-5: Device not responding to setup address.
[ 4997.645376] usb 3-5: Device not responding to setup address.
[ 4997.848656] usb 3-5: device not accepting address 14, error -71
[ 4998.008680] usb 3-5: new full-speed USB device number 15 using xhci_hcd
[ 4998.008806] usb 3-5: Device not responding to setup address.
[ 4998.212106] usb 3-5: Device not responding to setup address.
[ 4998.415345] usb 3-5: device not accepting address 15, error -71
[ 4998.415374] usb usb3-port5: unable to enumerate USB device
