water flow rate
Go to solution Solved by 0ld_Chicken,
It looks like you're just below 1gpm which is pretty good and normal. Most blocks don't scale very well above 1gpm so you probably wouldn't notice a big difference in temps.  If you want to be sure, find a review for your exact blocks that shows performance at different flow rates.  Some scale better than others
(xtremerigs.com and thermalbench.com are usually my go-to sites for watercooling reviews)
Edit: for example, ek's gtx980 block would maybe show .2°c improvement from adding another pump. Maybe .5° from 2 additional
Hi,
i'm new here this is my first post, hello everyone :)
I'm running a water cooled rig, with a single loop cpu + 3x gpu + 2x 480rad + 1x 360rad + 1x 140rad
the loop is powered by a ek d5 bay res pump. current water speed is 220 liter per hour. (with max pump speed)
under heavy gpu+cpu load temps get to around 45-50C.
question: would i benefit from higher flow rate?
i'm thinking about adding a ek dual d5 pump to the loop and running the system with 3 pumps, but i'm unsure how much it would help regarding temps!
(or even dropping the bay res and going only for the dual d5 would also be an option)
https://linustechtips.com/topic/686126-water-flow-rate/
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/686126-water-flow-rate/#findComment-8811427
