its my first time building a pc and i want to check if my choise of parts is good. my budget is on 1500$ and i have a list with just under that, please check it out if there is any thing i shuld change or add.
Hard drive: WD Blue 2TB Desktop Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EZRZ
Ram: Kingston Technology HyperX Savage Black 16GB Kit (2x8GB) 2666MHz DDR4 CL13 DIMM XMP Memory (HX426C13SB2K2/16)
Motherboard: Gigabyte LGA1151 Intel Z170 ATX Motherboard ATX DDR4 NA Motherboards (GA-Z170X-GAMING 5)
Grapics card: MSI GAMING GeForce GTX 1070 8GB GDDR5 DirectX 12 VR Ready (GeForce GTX 1070 GAMING X 8G)
Disk drive: Vantec USA NexStar DX External 5.25-Inch Optical Drive Enclosure USB 3.0 External Interface Optical Drives 14700365 (NST-530S3-BK)
Cpu: Intel Boxed Core I7-6700K 4.00 GHz 8M Processor Cache 4 LGA 1151 BX80662I76700K with Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
SSD : Samsung 750 EVO - 250GB - 2.5-Inch SATA III Internal SSD (MZ-750250BW)
Cahssi: NZXT Noctis 450 Midi Tower
power: EVGA SuperNOVA 750 B2, 80+ BRONZE 750W, Semi Modular, 5 Year Warranty, Includes FREE Power On Self Tester, Power Supply 110-B2-0750-VR
all this goes for abot 1500$ on amazon right now.
for the other thing sutch as screens and stuff i thought
screen: AOC 27" LED Q2778VQE  2560x1440, 1ms, 80m:1, VGA/DVI/HDMI/DP
Keyboard: steelseries apex 350
mouse: Razer deathadder
headset: logitech g35
only international items....
Thank you!
https://linustechtips.com/topic/685821-need-help-with-computer-parts/
you should use pcpartpicker.com
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
drop the 2tb WD blue for a 1tb wd blue and add a samsung 850 evo 250gb ssd instead. Also here is /r/buildapcsales great place to look for awesome deals that are going on right now
>WD 2TB HDD is only 5400 RPM, go for seagate barracuda with the new green label versions
>get the higher quality EVGA G2/GS/GQ units, also 750W is overkill
>memory sticks are too expensive, you can have 16GB for $75-85
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
Black and White build, what do you think?
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($337.12 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($44.47 @ Amazon)
^better and nicer looking budget cooler
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($124.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($91.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($103.11 @ Amazon)
^you get can something cheaper like Crucial MX300 275GB or SK Hynix SL308 250GB for $70
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($79.12 @ Amazon)
^this the seagate drive ive mentioned
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($419.18 @ Amazon)
^MSI Armor OC is great here as well
Case: NZXT Noctis 450 ATX Mid Tower Case  ($139.99 @ Amazon)
^nice case but you could go for a cheaper one (ex. CM Masterbox 5 or Phanteks P400S for ~$60) so you can have a 240mm liquid cpu cooler
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($82.80 @ Amazon)
^did you know you whole system wont even consume over 300W?
Other: Vantec USA NexStar DX External 5.25-Inch Optical Drive  ($50.83 @ Amazon)
Total: $1411.72
Total: $1411.72
it would work but i cant use pc part picker since it dousent support any scandinan countries. and the reason i picked that ram was cause i couldent find any with a speed the motherboard would support and that was higher.  but thank you on the advice on the power and hard drive
shoulda just mentioned w/c country you're from...
you mobo can support any speed DDR4 ram
