How much difference does a case make to cooling?
Solved by Gonio,
They are very close together in normal cooling performance. The Noctis has slightly lower temps +/- 2 degree C, while the 440 is more silent. So for your CPU/GPU it doesn't really matter. So go with your 440.
Note here that how things look like, might not always be a actual indication it would perform less. The 2 degree difference is well within a acceptable margin of error, so the visual restriction it might have over the other might not even be hindering it, as it doesn't with these cases.
