22 minutes ago, Perche25 said:
Im looking to move my pc into a smaller case before I go off to college. I would really love for it to have a windowed side and if possible can fit a full sized ATX motherboard
Well if money doesn't matter then I'd imagine a Lian Li PC-07 would be great! But it isn't cheap.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
Check the phanteks line up, they have some great cases. Also coolermaster with the mastercase series are great.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
They both make nice cases, but they aren't really what I would call small. If you want a small case that fits an ATX board, pretty much the only dimension you have to shrink down on is the height from the motherboard to the covering panel. This forces you to go liquid or low-profile air, but that's not really an issue for 99.9% of people. Wall mount oriented chassis are the only cases I've seen that really do shrink down the standard ATX-compatible tower without losing motherboard compatibility.
