What case to choose
6 members have voted
  1. 1. Options
    • Mastercase pro 5
      1
    • Core p3 or p5
      2
    • H440/N450
      3
Hey LTT Forums :)
not really sure on what case to choose, been looking at reviews even went to look at few of these and still not really sure lol
looking for a smallish midtower for that has good rad capacity (at least a 240 and 360) and costing around $200 AUD
just let me know if you want more deets
Returning after 8 years dormant
https://linustechtips.com/topic/685621-case-options/
1 minute ago, SCHISCHKA said:
p5 & p3 is really for people who put a lot of effort into their plumbing. Id go for that.
was leaning towards the p3. i am planning on getting a modder to make the system when i have the coin :D so want to show off as much as possible
https://linustechtips.com/topic/685621-case-options/#findComment-8805930
1 minute ago, SmashinMachine said:
There are a lot of accecories to customize your build. And it has better quality and tight tolerances in Dimensions.
I love this tempered glass, nobody can imagine what is inthere
can you add a triple 120 in the front?
https://linustechtips.com/topic/685621-case-options/#findComment-8805973
34 minutes ago, Maverick5500 said:
Hey LTT Forums :)
Any particular reason you're not considering the Fractal Define S? Sounds like the sort of thing you're interested in.
https://linustechtips.com/topic/685621-case-options/#findComment-8805977
not a massive fan (lol) not going to lie. its a good case just not for me :)
https://linustechtips.com/topic/685621-case-options/#findComment-8805984
This piece of sheet had no functions. (no screws nothing) And you will not see if you install the I/O Panel. The recess of that cutted sheet was for the cables of I/O Panel. I made the recess only bigger
I used my old friend Dremel. It cost me 5 min.
https://linustechtips.com/topic/685621-case-options/#findComment-8806009
nice. with the 420 can you also fit a 240 up top?
https://linustechtips.com/topic/685621-case-options/#findComment-8806011
