I am going to buy nzxt phantom 530, but cannot find anywhere how thick radiators it support.
I am going to get at least 360mm + later 280/240mm rad later for gpu.
I will cool:
i5 4670k
gtx 770 (maybe another too, who knows!)
So how thick and what fpi rad + fans should I get for that setup while having some airflow for mobo vrm.
Curing shitposts by shitposts
https://linustechtips.com/topic/68516-what-radiator-fans/
It should be mentioned in this review http://www.overclock3d.net/reviews/cases_cooling/nzxt_phantom_530_review/1
-edit, ah maybe not. (usually is when TTL does the reviews himself)
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/68516-what-radiator-fans/#findComment-938739
Apparently it can support thick radiators and you can put the fans above the mounting mechanism for the radiator. i can't find anywhere that says supported radiators though. Maybe you could search for some build logs to check it out
https://linustechtips.com/topic/68516-what-radiator-fans/#findComment-939047
Alphacool (XT or UT series) + Scythe Gentle Typhoons, can't go wrong :) unless Noctua's color scheme matches yours...o__o then get noctuas :)
I'd go low fpi (~10) so you can undervolt the fans and enjoy peacee
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
https://linustechtips.com/topic/68516-what-radiator-fans/#findComment-946338
