Timelapse Method?
Solved by Bsmith,
9 minutes ago, Implosivetech said:So I can record longer time lapses. On my phone, I have a 32gb micro sad card for the timelapses聽lapses
32GB should be enough for timelapse photography, since it generally is just alot of photo's taken over a long time period, but if you decide to do this by fast playing a clip then you will need quite a bit more of space yeah, I would see first if you are able to send data from your phone over USB to your pc directly before going through the trouble of setting things up while you aren't sure if it's possible.
But like my first post, I would suggest looking into a timelapse app in the google play store, since that would allow for a better experience later on.
