7 minutes ago, Daveeede said:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($195.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($17.88 @ OutletPC)
Motherboard: MSI H110M Gaming Micro ATX LGA1151 Motherboard  ($51.98 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($37.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($73.80 @ OutletPC)
Video Card: MSI Radeon RX 480 8GB GAMING X Video Card  ($244.99 @ Newegg)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $722.51
Generated by PCPartPicker 2016-11-02 17:29 EDT-0400
Remove the CPU cooler, get a cheaper GPU and add an SSD if you want.
thank you :)
https://linustechtips.com/topic/684769-help/page/2/#findComment-8797914
6 minutes ago, Toprightbenj said:
UK but it was easier putting it like that compared to £620
Ah, well because of shenanigans 620 pounds is less than 750 US dollars for the purposes of building a computer :P
This list is for the UK.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£183.05 @ CCL Computers)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  (£50.94 @ CCL Computers)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  (£43.90 @ CCL Computers)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  (£37.91 @ CCL Computers)
Storage: *Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£47.96 @ CCL Computers)
Video Card: *MSI GeForce GTX 1060 3GB 3GB GT OC Video Card  (£189.07 @ CCL Computers)
Case: Corsair Carbide SPEC-M2 MicroATX Mid Tower Case  (£52.69 @ CCL Computers)
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply  (£37.55 @ CCL Computers)
Total: £643.07
Generated by PCPartPicker 2016-11-02 21:42 GMT+0000
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/684769-help/page/2/#findComment-8797930
Total: £643.07
Ahhh I see sorry I never thought about that, will go have a look thank you :))
https://linustechtips.com/topic/684769-help/page/2/#findComment-8797983
On 02/11/2016 at 6:38 PM, Toprightbenj said:
i will keep doing research and get advice from people and see what the best i can build is, thank you
http://uk.pcpartpicker.com/list/fz6YWX
http://uk.pcpartpicker.com/list/nTvp3F
both are at my budget, which would you recommended ?
https://linustechtips.com/topic/684769-help/page/2/#findComment-8802678
For current games and requirements for them the I3 will perform better due to the higher 'per core' performance, so I would go with that one, along with it having 2 ram dims in the build, dual channel makes a huge difference!
However I would just keep in mind. According to trends and what a lot of people are saying, games are starting to make better use of more cores, thus eliminating most gains from high 'per core' performance. So get the I3, but plan to get something with a quad core later on with a better core performance.
Overall I think you are taking the right steps when it comes to getting into building pc's, taking your time and making educated decisions. Keep it up man!
I look forward to seeing the end result.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/684769-help/page/2/#findComment-8805636
Sorry just saw this. Thank you for the support means so much :)) yeah I have been doing research and trying to work out the best for my budget, I have made lots and lots of different builds and made another again that is at the max of my budget
http://uk.pcpartpicker.com/list/gqDp3F
https://linustechtips.com/topic/684769-help/page/2/#findComment-8808803
Sorry for the delayed reply XD, The only thing I would really suggest changing with that build is to go with a 2x4 gb ram kit instead of 1x8 gb. dual channel ram makes a huge difference in speed.
https://linustechtips.com/topic/684769-help/page/2/#findComment-8816906
no bother sorry about mine as well xD, sorted! changed it to a 2x4gb instead, Thanks !!
https://linustechtips.com/topic/684769-help/page/2/#findComment-8823846
