Hey guys a friend is trying to mine a new coin but he doesn't know alot regarding the hardware part of it, he's more the configurations guy.
He wants a rig that has around 4-5 GPU's , its going to be GPU only type of mining, any ideas are welcome
This is what he had in mind so far :
-ASRock H81 Pro BTC
-5x rx 470
-Any haswell Dual Core cpu.
-A solid 850w power suply
Questions regarding current ides :
- Will Pci-e 1x be enough for the 470 when it comes to mining , bandwidth wise and all?-
-What about ading a 1x -16x extender or PCI -USB risers > will those give enough bandwidth?
-What about PCI -USB risers?
-What should I change in the rig?
The faster we do the purchase the better
https://linustechtips.com/topic/684655-mining-rig-help/
15 minutes ago, Tiber1337 said:
Questions regarding current ides -
Will Pci-e 1x be enough for the 470 when it comes to mining?
No. If the slot is physically x1, it won't work and may hinder performance of the GPU.
what about ading a 1x -16x extender?
It'll fit the GPU but the total speed will be PCIe x1.
what about PCI -USB risers?
Won't work as the RX 470 only comes in PCIe.
Go for two cards as the CPU doesn't have the lanes to support 4 or 5 cards in SLI.
You should think this through.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795209
Yes, more then enough bandwith, you will need to use Powered RISERS though!
Quote
Bandwidth is 9/10 not the issue it's power.
Quote
I'm using the following risers: https://mineshop.eu/cables/pci-e-1x-to-16x-powered-usb-riser-ethereum-mining-detail (Not in any way affiliated with them, they are just the closest shop for me with these risers)
Quote
Maybe a stronger power supply, because you do not want to run it at 90%+ of its capacity 24/7
Quote
Altcoint mining is a volatile market, don't invest into it if you cant miss the cash.
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795237
Is GPU mining still worth it?
I hear that this is already in the past since there are devices for it: AntMiner S7.
Just wondering if that's still true :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795271
Bitcoint mining is not worth it. There are a lot of new cryptocurrencys appearing that can only be GPU mined.
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795285
ASIC hardware compatibility depends on the mining program. I wouldn't do any mining to be honest and just invest in a mutual fund or something.
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795288
Yeah that's what I thought.
But may I ask what cryptocurrencys is worth to mine with GPU or CPU those days? If you maybe have any info regarding that.
I agree with that. But still, it's interesting idea to earn money from running program on your PC.
WD My Cloud 4TB
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8795322
your current build looks pretty good, like I said i recommend a higher PSU, like 1000 to 1200 Watt, check the efficiency curve and calculate what will be more efficient because after all to make a profit your costs's need to be as low as possible.
You can use unpowered risers but I would recommend against that, because every card is going to pull 75 watt from the motherboard and that will kill it over time.
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8797372
I might be that I can make the power cost be next to nothing nomatter the wattage
https://linustechtips.com/topic/684655-mining-rig-help/#findComment-8797661
