Hello, does anyone here know of a psu that's at least a tier 2 from @STRMfrmXMN's psu tier list that has black or white sleeved cables - (pre sleeved by manu) any psu with white presleeved cables would be fine too - i'd just like @STRMfrmXMN to confirm that the psu is of good quality
Thanks in advance especially to you STRM
https://linustechtips.com/topic/684000-psu-help/
You want a PSU whose cables already individually sleeved?
Uh...I know of the Bitfenix Fury that's based on a mediocre FSP Aurum platform...
There's the Enermax Platimax D.F. which isn't widely available and a bit expensive. Based on the same Fortech platform as the Segotep GP-P, IIRC (don't have time to validate).
You probably better off just getting a CableMod compatible or similar power supply and buy a kit from them.
https://linustechtips.com/topic/684000-psu-help/#findComment-8787725
There aren't a whole lot of them. I'd just get a modular PSU and get sleeved cables. They exist in abundance for the G2 if you want.
https://linustechtips.com/topic/684000-psu-help/#findComment-8791191
