Don't know the program, but seems a bandwith issue... You also have this with other programs doing the same?
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/683684-svp-audio-cutting-out/#findComment-8784135
no. its just SVP. SVP interpolates the video to display it in a higher frame rate than its usual to sync to the hz of the screen you are using. It worked fine up until a few weeks ago.
https://linustechtips.com/topic/683684-svp-audio-cutting-out/#findComment-8784693
3 hours ago, Runefox said:
Not familiar with the software itself, but I'm grabbing it now to take a look. Out of curiosity, are you using the paid version, and are you setting a frame rate target? What does the CPU / GPU usage look like?
i am using the paid version. I never had too much luck with the free version. Ill test the CPU and GPU usage in a bit and get back to you about it
https://linustechtips.com/topic/683684-svp-audio-cutting-out/#findComment-8786752
