This is happeneing to my PC since the last few days.
NO BSOD, just goddamn reboots sometimes back to back. sometimes once in a month.
The first time it happened i shrugged it off.
Now its a perpetual Cluster**** of reboots. Sometimes when i game, sometimes when i'm doing my projects. Hell, I hope it doesnt crash as I type this !
The following was shown in the event viewer
- System
  - Provider
   [ Name]  Microsoft-Windows-Kernel-Power
   [ Guid]  {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
   EventID 41
   Version 2
   Level 1
   Task 63
   Opcode 0
   Keywords 0x8000000000000002
  - TimeCreated
   [ SystemTime]  2016-10-31T02:00:53.359217300Z
   EventRecordID 176235
   Correlation
  - Execution
   [ ProcessID]  4
   [ ThreadID]  8
   Channel System
   Computer HOME-PC
  - Security
   [ UserID]  S-1-5-18
- EventData
  BugcheckCode 0
  BugcheckParameter1 0x0
  BugcheckParameter2 0x0
  BugcheckParameter3 0x0
  BugcheckParameter4 0x0
  SleepInProgress false
  PowerButtonTimestamp 0
I honestly appreciate any help. I am not a techwiz so any programs that are to be run will have to be run by someone else, i.e. a mechanic/ software engineer.
THANKS ALL !
https://linustechtips.com/topic/683508-kernel-power-why/
Is there any pattern to it or a certain amount of time that has to pass before the cluster attacks?
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782464
No.
three days ago there were two reboots in an interval of five hours.
two days ago there were three reboots in intervals of 30 mins each.
yesterday nothing !
today, two in the interval of one hour
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782478
Because of it's inconsistent nature you need to get information from the event veiwer immediately after a reboot occurs. There are outer a hundred things that could cause this rebooting and without information from the event veiwer after one happens it could take an excessive amount of trial and error and time. Get the information from the event veiwer and post it to zero in on the problem.
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782522
thats the point i dont get. Where do i look. it literally just happened again !
where in the event viewer should i look ?  please help !
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782542
is it this perhaps ?
Session "ReadyBoot" stopped due to the following error: 0xC0000188
  System
- Provider
      [ Name] Microsoft-Windows-Kernel-EventTracing
      [ Guid] {B675EC37-BDB6-4648-BC92-F3FDC74D3CA2}
  EventID 3
  Version 0
  Level 2
  Task 2
  Opcode 14
  Keywords 0x8000000000000010
- TimeCreated
      [ SystemTime] 2016-10-28T13:37:54.638195500Z
  EventRecordID 4
  Correlation
- Execution
      [ ProcessID] 4
      [ ThreadID] 212
  Channel Microsoft-Windows-Kernel-EventTracing/Admin
  Computer Home-PC
- Security
      [ UserID] S-1-5-18
- EventData
    SessionName ReadyBoot
    FileName C:\Windows\Prefetch\ReadyBoot\ReadyBoot.etl
    ErrorCode 3221225864
    LoggingMode 0
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782560
Turn off readyboost and remove any jump drive that is being used for readyboost. What version of Windows are you using?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782581
please tell me how to turn off readyboost and also the jumpdrive thing please.
and its on Windows 7 ultimate
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782592
Do you have a jump drive or any other drive on this PC?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782604
It could even be a SD card in a printer...
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782608
So if you right click on " My computer "  and open it up the only drives listed is " C" and system reserved?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782628
What drives are listed in your computer?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782676
Must of blue screened.....
Download CCleaner and run it. Make sure to go into the advanced settings any check off clear prefetch.....
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8782744
Ok... lets go old school.
Last event log you show indicates that the Ready Boot has stopped. Ok lets see if disabling it will stop the blue screens as problems with ready boot can cause the blue screens. Here's how to do this:
Run the "Performance Monitor".
Go to "Data Collector Sets" on the left.
Double click "ReadyBoot" on the right.
Go to "Trace Session" tab.
Remove check mark from "Enabled" box.
Reboot and delete c:\windows\prefetch\ReadyBoot folder.
You will also need to disable the thumbnail caching tool as well for this to work properly:
1: open up the group policy editor (Run: MMC) and open up all users (user configuration>Administrative templates>Windows components>File explorer or windows explorer then turn off thumbnail caching and select ok. close the local group policy editor and restart.
This will stop the ready boot from running and also disable the thumbnail caching which is tied to readyboot and should stop the event problems due to ready boot
DO THIS AT YOUR OWN RISK.
People do this all the time but I always say this because you are changing the default configuration of the windows OS.
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8784240
I truly appreciate your help. I wont be risking, taking the above as i am new to computers and paranoid to muck things up.
I spoke to my tech guy who assembled it for me he says we'll have to format the pc and see if the problem persists.
I'm keeping ther thread open till then.
I'm really sorry for taking so much of your time. But i do appreciate your help.
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8784262
No problem on the time thing. Almost always a wipe / format / re-install will clear up the problem. Windows is kind of like a dust bunny.... over time it gathers so much stuff and it starts to create problems and it needs to be cleaned out or corrected. Sorry that you are having the issue, I am certain that a Re-install will resolve the problem.
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8784280
Thanks yo. Taking my system out for servicing right now. Will repost on the situation soon.
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8788355
  • 2 weeks later...
Hey ! Its been about two weeks. I got my mobo replaced under warranty, did the wipe/format and the problem still persists.
now i figure its my GTX 960 4GB AMP! Edition by ZOTAC.
The moment i replaced it with my older GPU, the GT 610 (crappy GPU),  The Kernel Power Crashes Instantly Stopped.
Now here's my dilemma. The 610 doesn't require the PCI-E Cables, whereas the 960 requires an 8 and 6x2 PCI-E cable from the power supply to the GPU.
The power supply is a 500W power supply and i assume that it should be compatible with my Graphic Card.
Shorter version of my new question, Is It the GPU (gtx960) or the power supply?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8848843
• NVIDIA specifies a minimum of a 400 Watt or greater system power supply. (Minimum system power requirement based on a PC configured with an Intel Core i7 3.2GHz 130 Watt TDP processor.)
• the system power supply must also have a maximum combined +12 Volt continuous current rating of 28 Amps or greater
• the system power supply should also have at least one 75-Watt 6-pin PCI Express supplementary power connector. There are some non-reference design cards that require two 75 Watt 6-pin PCI Express supplementary power connectors (e.g. Gigabyte GTX 960 G1 Gaming 2 GB [GV-N960G1 GAMING-2GD REV.1.0], Inno3D iChill Geforce GTX 960 2GB Ultra, etc.) or one 150-Watt 8-pin PCI Express supplementary power connector (e.g. EVGA GTX 960 SSC 2 GB [02G-P4-2966-KR], MSI GTX 960 Gaming OC 2 GB [GTX 960 GAMING 2G], etc.).
look at the specs on your specific power supply to see if it meets these specs at a minimum.
What brand/model of PSU are you using?
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8857057
Hi. Thanks. Im using an Artis 500w power supply. Seemed like a good recommendation for the price here in India. And yes, it does meet the minimum.
Also. Its probably not the GPU. It seems to happen on my Gt610 as well.
Now its either my processor or Power supply or my Wall electrical output thats messing up my PC
https://linustechtips.com/topic/683508-kernel-power-why/#findComment-8874137
