Board         asus z170 maximus VIII Hero Alpha   294,38€
GPU           EVGA Geforce GTX FTW 1080         866,4€
CPU           Intel core i7-6700k                             345,9€
RAM           Gskill ripjaws 2x8GB 3000mhz           108,65€
Cooler        cryorg r1 ultimate                               87,9€
SSD           sandisk 950 pro                                  199,48€
HDD           seagate 3TB                                       95,95€
PSU            evga supernova 850 g2                     163,25€
Case          be quiet! SILENT BASE 800               157,78€
        Total     2319,69€
Prices are based on the Portuguese market :P
I'd like any advices, the budget can be changed (preferably down but might also go up xD)
Pc will be used mostly for gaming, i'll also buy a predator x34 monitor.
https://linustechtips.com/topic/683251-advice-for-this-build/
9 minutes ago, RUWO_builder said:
I dont know the Portugese prices,but the ram seemes way to expensive.
also,i would go with a 6600k.
Euro's is even worse then Canadian Rupees.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779716
Yeah, this sums up. Prices are pretty inflated because VAT (and other things that I'm not aware of)
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779729
Advice: Get cheaper motherboard. And dont get an EVGA GPU (as far as im aware its only the FTW editions of GTX 1070 & 1080) , they have problems with their VRMs at the moment.
28 minutes ago, DevilMessias said:
PSU           be quiet! SILENT BASE 800                163,25€
That is the name of case, not a PSU.
Edited by Guest
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779768
Just now, HydraGaming said:
Advice: Get cheaper motherboard. And dont get an EVGA GPU, they have problems with their VRMs at the moment.
HAHAHAHAHA true i replaced the wrong line xD ty for pointing it out,1 sec i'll edit
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779774
1 minute ago, DevilMessias said:
Done. Any recommendations on the board & GPU?
For GPU: MSI's Gaming X / Zotac's AMP (or AMP EXTREME) / Asus Strix
For Mobo: Asus Z170-A or Asus Z170 Pro Gaming. Model doesnt matter that much, just dont pay for features you're never gonna use.
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779808
Assuming you get an EVGA with missing thermal pads you can notify them of this and send them to you. No biggie.
PSU Tier list
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8779878
There's no need for DDR4-3000 RAM. RAM speed makes very little difference. Just get ordinary, cheaper DDR4-2133 0r 2400.
Your build really only needs a good 500watt 80+ bronze power supply, such as a Corsair CX550M. Even 650watts is enough for 2 1080's in SLI. (Or a 500-550watt 80+ gold if you want.)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8780156
I would stay with the 6700K. i5's are starting to get maxed out in games. They do bottleneck 1080's and even 1070's in some cases. He will have less stuttering and frame drops with an i7. It would be better to save money on the motherboard.
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8780309
I actually do notice the difference between 2133 and 3000 MHz RAM in games. Not so much in fps but the game is much smoother and there is no microsuttering.
https://linustechtips.com/topic/683251-advice-for-this-build/#findComment-8780316
