From the little I know about Pascal, it doesn't matter performance wise. Go for whatever looks best to you.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/683214-two-fans/#findComment-8779240
2 minutes ago, 'kallu said:
Is it worth buying GTX 1060 with two fans? Should i buy with only 1? And what is the best manufacturer? Im going to play at 1080p and high/v.high.
A cool card is a happy card, and if you're going to OC, that second fan is nice to have.
All the major card partners are more or less the same. It depends on looks, noise and customer support. Looks are entirely subjective, noise is largely influenced by the cooling setup (another plus for dual or tri-fan designs), and in terms of customer support, EVGA is the best, Gigabyte is the worst, and everyone else is somewhere in between.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/683214-two-fans/#findComment-8779253
