Long time reader first time poster :) So, I just finished my first build and installed an H100i. I had problems with the installation for example I rubbed off some of the thermal compound (by accident) and I believe the back plate is not positioned correctly thus the block isn't making full contact. My plan is to strip the PC and put on some new compound and reinstall the cooler. I'm running a 4770k it idles around 26-35 and on 100% load I reached 80+! Any theories on why I might be facing these issues? Thanks in advance :)
https://linustechtips.com/topic/68187-h100i-high-temps/
I had the same thing happen with mine, reseat with new paste and make sure the backplate is snug.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-933764
first off, welcome to LinusTechTips forums.
depending on what app you are using to stress the CPU to get your 80°+ does sound
like it is correct and no amount of mount/remount will cure this issue. Haswell seems
to not play well with certain applications and depending on motherboard package, some
incorporate an adaptive mode that will yield higher than manual clocking temperatures.
i'd say at this point you have no issue unless your ambient temperature is less than 15°.
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-933770
This is also true with Haswell and non custom loops, Thx for reminding me :D
Lance.
Sent from my Galaxy S4
Using Tapatalk
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-933807
Yeah, the backplate for the H100i CAN go on 2 ways, but there's only 1 way that's right, if it's on the other way it can be lose and you lose tight connection between CPU/Cooler, so reapply TIM, and make sure the backplate is on right!
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-933856
I was running prime95 so that might have been why.
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-933931
If i remember correctly the backplate has a notched side that should face the top of your mobo to accommodate the existing Intel retention bracket's two screws that stick out. As for thermal paste i go with MX4 because its non conductive and non capacitive. Also, use Aida64 to stress test. GL
Corsair 250d - - Delidded i7 4770k @ 4.4GHz (1.15v) - - Asus Maximus VI Impact - - Corsair h100i
Asus DirectCU II OC GTX780 - - NZXT x41 & G10 w/ Push/Pull Noctua IndustrialPPC's - - Corsair ax760i
16GB Corsair Vengeance 2133Mhz  - - Samsung 840 pro (boot) - - Samsung Evo (gaming) - - WD green HDD (data)
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-934021
I had a similar issue with my H100i and so I cleaned off the thermal compound and applied my own! Then all my temps were just fine. Also when I did this I removed the 2 stock fans for NF-F12!!! (Highly recommended for the future)
CPU: 3770K | Motherboard: Asus Maximus V Formula | GPU: GTX 1080Ti SLI | Ram: 16gb Corsair Dominator Platinum 2133 | PSU: Corsair AX1200i | Storage: 2x Samsung 840 pros | Case: Corsair 650D | Cooler:  Corsair H100i with Noctus NF-F12 fans | Monitor: Asus ROG Swift PG278Q
https://linustechtips.com/topic/68187-h100i-high-temps/#findComment-934083
