Hi Guys
Its my first post here and i came seeking advice from pc veterans since im a total noobie, i own a desktop hp pavilion idk which model which is prebuilt and i wanna change the graphic card now unfortunately im on a budget a big one and i would like a good performing graphic card for mmorpg games and so on a decent card. here is my stuff https://gyazo.com/55fff49a9092201cdde77df390f4f240 as u can see i have a pretty shit graphic card which can only play league at high i struggle on lowest for overwatch etc, i thought about the 1050 ti because it doesnt require any pin and fit my 300 psu if you have any other option i would like to hear. Now the main question is if i buy the 1050 ti will it work can i just plug it in the pcie x16 and it will work or is there some other stuff i need to confirm im worried about buying the card and then cant refund it and it doesnt work on my pc.
Thank you for taking the time to read and for you who answer.
https://linustechtips.com/topic/681770-need-advice-for-upgrading/
As long as the card can physically fit into the computer, you should be fine. Some OEM's use funky motherboard layouts and I have seen in some Dell systems where the first PCIe slot cannot accept a double wide GPU because it interferes with the CPU heatsink.
When in doubt, re-format.
The only problem here is i live in sweden, the 1050 ti is supposed to cost 140 dollar which turns to around 1200 Kronor ( swedish value) but instead they sell it for 2000 Kr which is increased by around 800 kr which equals 100 dollar. Is there any amazon alike thing for europe because amazon shippin cost 85 dollar.
