What Wireless Headset?
6 members have voted
  1. 1. Poll
    • Logitech G930
    • Corsair VOID WIreless
    • Other (Comment) (must be under $100, must be wireless, must be over ear, must have decent mic, does NOT HAVE to be 'gaming')
I am considering replacing my Razer Kraken Pro 2012 with a new wireless one. The sound quality is fine of the Kraken Pro. I don't have high standards, and most of the time find myself only using one ear cup. As long as they are same as or equal to the Kraken Pro. I do care a little bit about the Mic. It MUST be better or equal to the quality of the Razer Kraken Pro 2012.
The two headsets I am currently looking at are:
Corsair VOID Wireless 7.1 RGB
NEW: ~$100
USED: ~$85
Logitech Wireless G930 7.1
NEW: ~$70
USED: ~$50
The VOID looks and seems better than the G930.
But the G930 has a lot more attractive price.
If you have another preference please post it! It does not HAVE to be a GAMING headset, and actually prefer the looks of normal headsets. As long as it is Over Ear, has a quality mic, is WIRELESS, and is under $100.
IT MUST BE Wireless because I hate wires. I will ignore all non wireless ones.
Thank you!!
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
https://linustechtips.com/topic/681677-what-wireless-headset-to-get/
NEW: ~$100
USED: ~$85
NEW: ~$70
USED: ~$50
Thank you!!
Go for Corsair vengeance 2100s if you can find them, if not, G930s.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Why do you recommend these? They appear to be quite aged. Do you own one?
My System:
My Phone:
My Watch:
I owned VG930s, my friend owns 2100s. They have much better audio quality than anything else out there. I currently have G933s
Solitaire.
Better than the 933s? Those things cost $150!
Which set are you referring to?
Apparently Corsair is worse than Razer when it comes to naming.
There is the
Corsair Vengeance 2100 (2013)
Corsair Gaming H2100 (CA-9011127-NA)(2014)
Corsair Gaming H2100(CA-9011136-NA)(2015)
The only apparent difference in the 2015 and 2014 models is a color difference. It looks like the original color was black and gold and then the 2015 model is fully grey.
The 2013 Corsair Vengeance just looks like the older version. Which are you talking about? Do you know this for sure? Have you actually compared the headsets? Thanks.
PC world says the VOID is better....
http://www.pcworld.com/article/3088750/hardware/corsair-void-wireless-review-this-headset-is-your-best-bet-if-you-must-go-wireless.html
Corsair seems to be more proud of the newer VOIDs.
From what I understand, the H2100 are the older-designed, more general headphones with great battery life and quality sound, while the VOIDs have more technology in them and are prettier with more bass. Apparently it suffers in the battery department when the RBG is used.
The VOIDs have also seems to be more popular, with even Hardware Canucks making a video on it.
My System:
My Phone:
My Watch:
There is the
I have no experience with the VOIDs, but I can confirm the Vengeance 2100s have much better audio quality than Logitech headphones.
Solitaire.
I'd recommend the Void Wireless, i have them myself and although i'm looking for headphones rather than a gaming headset atm i have never had any problem with these. They are comfortable, sound quality is pretty good nothing spectacular but not bad, i have never ran out of battery, easy to keep charged up and the mic quality is pretty good too. Check out this review for more, I got mine pretty cheap last year on black Friday so maybe wait for that.
