Ok so I need help picking a sweet looking case that can fit all my parts http://pcpartpicker.com/list/ I've been looking at a deepcool (the one listed) as it has cool leds and is cheap. But honestly if you guys have any good case recommendations for under 50 US dollars I am open to changing it.
https://linustechtips.com/topic/681535-help-picking-a-case/
Your list?
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763017
NZXT S340
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763034
18 minutes ago, akela said:
hit the link it should work
you have to use the permalink above the list, not the actual URL. The case you picked out is a good case. $50 is a pretty tight budget for a good looking case but the tesseract or whatever is a good pick
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763084
ahh thanks for the help for the url
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763090
15 minutes ago, akela said:
what would you say is a good budget for a case?
Well I said good looking case. and looks are all opinion. I think cases tend to look better in the 100ish dollar price range. you can have a totally different opinion. Theres nothing wrong with the case you picked lol its great for its price
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763119
lol ok thanks so much, maybe later down the road the case will be upgraded
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763121
i just in your list that you chose a TJ08e.....I had that case and it is kinda nice, but has pretty bad temps for gpus unless you have a blower cooler. It is very compact for mATX though. Just fyi.
Also, when buying a case, one should rather spend more on a quality case, because that is something that may last several upgrade cycles.
I just bought the nano s from fractal and I have to say this is probably my last case for a while. It basically has everything I want and is fairly small AND it will support water cooling.....I am not sure if I want that yet, but it is nice to have support.
The mentioned s340 is a great case btw. Very solid and low price for what you get. If I wanted atx, that would be my choice.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/681535-help-picking-a-case/#findComment-8763142
