Ok i have 2 980TIs running in sli and a 950 so i can use my non gaming monitors. Well the problem is when i run 3d mark or any other benchmark it only shows one of the 980s and the 950 being used while the second 980 remains 100% idle. I dont under stand because when it was just the 2 980s everything worked fine. It wasnt untill i added the 950 that the other 980 stayed in idle. And before you ask yes i made sure sli is enabled and my gaming monitor is plugged into the sli 980s. And im running a 1300 watt power supply so i got plenty of juice. Any body have any ideas let me know
https://linustechtips.com/topic/681457-sli-problems/
Maybe the cpu cant support the lanes or the mobo has to drop down the pci speed.
https://linustechtips.com/topic/681457-sli-problems/#findComment-8762404
Just plug the other monitors into the second card then nvdia controll panel and select sli/souring tab and there's a option to enable other displays no need for the 950
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/681457-sli-problems/#findComment-8763277
