the ram or the vram on the 580
The ram in the system, is your 580 running at stock speeds
Intel I7 2600k @ 4.5ghz, Asetek 510 LC Xtremegear liquid cooling system, PALIT GTX 780 Super Jetstream OC, 8Gb Kingston Hyper X blu series 1600mhz, 64Gb Crucial M4 series SATA III Gaming MLC SSD, 1TB Western Digital HDD 6.0gb/s,  Asus P8z68-v Pro Motherboard, Corsair Vengance K90 Keyboard,950Watt Cyberpower PSU, Cyborg RAT 5 ,  Coolermaster CM 690II case, Dell Ultrasharp U2412M 1920 x 1200
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-935287
yes the 580 has not been overclocked at all and the system ram it at its stock 1600Mhz
What windows version are you using?
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-935305
iam using windows 7 home preieum
Is that the 64 but version i assume?
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-935321
yes
Ok cool, so what games are u running? Also resolution and settings for the ones that stutter
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-935333
i use an 24 inch 1080p and ultra setting on bf3 ond then i was also playing blackops2 maxed out
Well i know for a fact the 580 can fairly easily
Max out bf3 and there shouldnt be stuttering. Just for the purpose of finding the problem though have you tried lowering the settings in these games?
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-935359
yes i just did and it didnt make a difference
I would suggest running prime 95 for 12 hours at least to see if your cpu is good and stable, then run 3d mark vantage for 6 hours on the gpu. See what score you get and any crashes, wierd artifacts etc
https://linustechtips.com/topic/68131-gtx-580-problems/page/2/#findComment-936547
